td9cowboy
In the editor when adjusting the positive and negative degrees of pitch on the blades, as long as the pitches are equal +/- center stick is zero degrees. If you have +10 positive and adjust the maximum negative pitch to like -3 to limit negative pitch here it shifts the center stick zero pitch position even though the curves are linear +100/-100. Can that be right? I can work around this with the curves but I would like to know if this shift under main rotor is intended or an oversight. If it is intended, what is it's purpose?
