I have attempted to finish the installation of KeMax via the following read me file but I am getting an error.
The first error reads. Entry Point Not Found
The procedure entry point ?GetRsrcString@ClassDesc@@UAEPADH@Z could not be located in the dynamic link library core.dll.
Click OK.
Then this error pops up.
DLL <C:\Program Files\Knife Edge Software\KEMax\Plugins\kemax.dle> failed to initialize. Error code 127 - The specified procedure could not be found.
What the???? I am not sure what I am doing wrong here. Should the path be to the folder or the "kemax.dle" file?
Here's the read me file text.
PLEASE READ: Additional steps required to complete product installation.
To avoid installation issues, the KEMax installer does not manipulate your 3ds Max installation in any way. Before you will be able to use the KEMax export filter, you will have to register it with 3ds Max. The following instructions will help you to do this.
1. Launch 3ds Max
2. From the "Customize" menu, select "Configure System Paths..."
3. Switch to the "3rd Party Plug-Ins" tab
4. Click "Add..."
5. Browse to the "KEMax\Plugins" directory. By default, this is either:
(32-bit OS): "C:\Program Files\Knife Edge Software\KEMax\Plugins"
-or-
(64-bit OS): "C:\Program Files (x86)\Knife Edge Software\KEMax\Plugins"
6. Specify a label for the new path entry, e.g. "KEMax"
7. Click "Use Path"
8. Click "OK"
9. Restart 3ds Max
When you choose to remove the KEMax export plug-in, you will want to remove the entry.
Click OK.
1. Launch 3ds Max
4. Click "Add..."
-or-
7. Click "Use Path"
8. Click "OK"
9. Restart 3ds Max
