Back when I had RF2, there were no 3D aircraft available. So, I designed my own using RF2 to simulate my own aircraft, which was 3D capable. After weeks of fine tuning, I was satisfied with the outcome. There are many adjustments that can be made to weight and balance, throws, power ratio, wing area, etc. that can be made to fit your needs with almost any aircraft that's similar to what you want. If you're going to do a search for something pre-made already, that is suitable to your exact wants, you may have a tough time.
Hi Flapper, thanks for the reply. I have been flying giant scale for over 20 years starting with the Hangar 9 Edge 540. I would not mind the Yak, Edge, Extra or the Sabach in either 1/4 scale or 33% gas powered. I have Real flight 8, been using RF from the time it came out in the late 90ies but will get the 9.5 soon.There are many, many. Decide on the airframe (Extra, Edge, Slick, etc., etc.) and the size. Then download and try. One man's realistic is another man's fantasy aircraft. Read up on the differences in the types of aircraft (EA vs CS vs AV, etc.) Many of the top 3D competitors in the country use RF for practice. With a little use of Google, you can easily find what they use, then download it from the swap pages here.
Give us some idea of the models and the sizes you are interested in, and you can get good suggestions.
If brand new, while waiting for those to come in, the stock Yak-54 is very good to start with.
I wish you good luck in whatever route you choose. I've found, for me, after a layoff, it was nerves and confidence, but I pursued and became more relaxed. Good Luck!
Hi Striker! I too have been flying RF since the 90's.... Just got 9.5 Sunday 10/03/21.. (yesterday) so after work today, I will try multiplayer....Hi Flapper, thanks for the reply. I have been flying giant scale for over 20 years starting with the Hangar 9 Edge 540. I would not mind the Yak, Edge, Extra or the Sabach in either 1/4 scale or 33% gas powered. I have Real flight 8, been using RF from the time it came out in the late 90ies but will get the 9.5 soon.
I have downloaded some airplanes from the swap pages but all seem too tame to fly. I just find that almost all of the airplanes seems too docile, doing touque rolls on RF is nothing to it in real life, looking for airplanes which has very close to the same characteristics as the real RC ones.
I have learned all of my 3D maneuvers on RF as far as input goes, but though not as realistic, its the stepping stone to get you off to a start with the real RC airplane and then to perfection. As I tell everyone, it helps you to master the stick input.
Thanks so much again guys.
