MultiMode with T6J - problem
rufus
Hi.
I'm using RF7.5 with the interlink elite controller.
I want to try multimode with my Futaba T6J but the program says "No controller found. You must have two controllers to enter MultiMode".
I have put my futaba is in "trainer mode". What am I doing wrong?
Hard to say, but definitely your radio is not communicating with RealFlight in the required way. Once you figure that part out, MultiMode will work.
There is lots of info scattered about the forums regarding setting up different radios. You may find this thread to be a good starting point.
Two main things things to consider:
  1. Your radio must output a PPM signal from the trainer port.
  2. Since you're using a Futaba radio, I'm assuming it has a square trainer port and you're using the cable and adapter included with your RealFlight package to connect it to your InterLink. Make sure the short adapter end of the cable is connected to your radio, not the InterLink. It matters.
You may find that you want or need to tweak the radio profile after your radio is detected. If selecting the Futaba profile in the Select Controller dialog doesn't quite get you where you want to go, it should at least be an excellent starting point.
