Need Help With Realflight Interlink Elite Controller
Metal-Steev
Hello -
I haven't played Realflight in some time now -
I hooked up an older desktop with Realflight G4 thru 7.5
and can't get any of the programs to "see" the controller...
The connector on the controller looks like a regular USB but it's kind of not-
It has what appears to be four holes where a normal USB has an empty space...
My question... does everyone else use a regular USB port on their computers
or do I need a special kind of port ???
Thanks
Steve
@Metal-Steev, did you get this sorted out? If not...
Exactly which controller are you using? It should say on the front whether it is an InterLink Elite, for example, or an InterLink Plus, or some other type of controller altogether. A picture might be helpful as well.
OK thanks. Unless someone has done some unexpected surgery on that controller, it definitely connects to a standard USB port. It may no longer be functioning correctly, though.
The first thing I'd do is open the Windows "Game Controllers" control panel and see if shows up there. If so, then I'd click Properties and see if things in there respond to inputs. (It'll look weird, but all that matters is whether things move in response to sticks and switches changing position). The bottom line is that if Windows sees the controller and it's working there, it should work in RealFlight, too.
The second thing I'd try is different ports on the same PC. Sometimes a port goes bad, and may work only partially, intermittently, or not at all.
If the above all fail, I'd try the same controller in a different PC, again attempting the same Windows Game Controllers test described above.
That should at least help triangulate the problem.
It says Interlink Elite by Futaba
I just pulled my RealFlight stuff out and dusted it off.
The original box was the RealFlight G4. That was for Windows XP. It came with CDs and the Interlink Elite Controller by Futaba.
I had also purchased the RF7.5 upgrade at some point in time. That was good for Windows 7/8.
I am now running Windows 11 64 bit. So the bit of bad news is that I purchased the newest version, yet again. I guess 3 times over 15 years or so isn't so bad I suppose.
The old "By Futaba" controller has a regular USB A connector.
Based on experience of others in this forum I just plugged the controller in and Windows 11 recognized it and installed device drivers for it. Easy Peasy.
I then just upgraded directly to "RealFlight Evolution" using my Steam account and it works fine with the old InterLink Elite Controller By Futaba that I originally purchased 15 years ago.
I assume you are familiar with using the Steam application to load and run programs? I purchased a copy of RealFlight Evolution. It runs fine under Windows 11.
As a previous poster mentioned, check for the existence of the game controller when it is plugged in. It took a little hunting but I figured out how to do it.
In the Windows Search bar look up "Set up USB game controllers". Under "Installed game controllers" mine shows "InterLink Elite" and a Status of "OK".
Under Properties I was able to calibrate it. The X, Y, Z axis and buttons were weird as one switch is a 3 position. Calibrating using the WIndows Game Controller was unnecessary as the "RealFlight Evolution" Steam App had it's own calibration procedure.
I attached an image of my controller. Like I say, it has a regular USB A connector. The only thing that I may not have on this older controller is the "panic" button. Channel 8 is a 3 way switch and it was used to switch between beginner/intermediate/expert modes in the training.
I also attached images of what to search for to bring up the game controller dialog.
