Please, help me what is wrong: (I use G4.5 version legal)
I download models that don't have textures applied. I try to apply following the steps of this tutorial exactly:
• Select the aircraft you would like to repaint.
• Go to the Aircraft menu and select “save color scheme as”
• Give the scheme a name and press OK
• This will create a TGA image file in the following folder …
C:\Program Files\RealFlightG4\ColorSchemes
• Edit this file in a paint package e.g. Photoshop or Paint shop pro (don't change the name or the file type)
• Launch Realflight and go to “select aircraft” and select the aircraft you created a custom scheme for. You should have an extra option under color scheme, choose it and your new scheme will be applied to the aircraft
I also try this too
What I do when re-doing a standard RF scheme is pick the plane you want to change .
(example) Nexstar-
1. load the plane
2 .save the scheme to Nexstar2 under "Save color scheme as"
3. load the saved scheme under "Select color scheme" Nexstar2
This will make a new dds.
4.Go to your Photo shop or Paint shop open the Nexstar2.tga from the colorscheme dir. and do what ever editing you wish and save the file as
Nexstar.tga, make sure it is saving a tga not psd ,turn of compression if it is on ,and make sure it is not saving the file as a copy. restart RF ,and it will make a new dds with your changes.
But....nothing!!! The color don´t change.
Thanks in advanced for your help.
(I don´t speak english very well. Sorry)
I also try this too
(example) Nexstar-
1. load the plane
