mgiesbre submitted a new upload:
Quad Turbine Delta v2_AV
View the Swap Page
This aircraft variant uses the previous Quad Turbine Delta variant as it's starting point. Various issues with the model design were discovered and fixed.
Model purists possibly may look "under the hood" and point out that my wing parameters don't follow the wire frame model's shape. That observation would be correct. The original model's wing design (NACA 5 wing foil, 0 degrees dihedral, 0 degrees angle of incidence) is a step or 2 above flying a model with...
View the Swap Page
