Aileron deflection set to +/-90 degrees -> shows +/-90 degrees on the plane.
Elevator deflection set to +/-90 degrees (which is the max. setting) -> shows just +/-45 degrees on the plane.
+/-45deg. elevator is not enough for some 3D-Maneuvers (~70deg. should be perfect), that´s why this is a real problem... Is there any way to fix this?
