Rudder movement limmited
Allandpm
My rudder excursion is limited on a full left and right turn. Full throw left and right. The Aeroscout or Aprentice barely makes a a turn. Have to use ailerons to make a turn. RF Evolution. Thanks
Press the "0" key on the keyboard to open the AS3X Nav Guide you're probably flying in SAFE mode. One of the switches on the InterLink controller will switch the AS3X modes. Normally there will be SAFE, AS3X, and AS3X listed. Both of the AS3X modes are the same so use the switch to set it to one of the AS3X modes (Not SAFE).
In real life, both of those planes automatically add low rates on the rudder when in Beginner or Intermediate mode.
The models in RF may be set the same way.
Thank you Technoid and flightengr, I switched to a a Night Timber (non trainer) and the rudder was more responsive. Safe Select was grayed out. On the real outdoor field my Aeroscout rudder yaw is more responsive.....definite turns than the Interlink DX Sim Controller. Maybe I should keep trying other planes that have Safe Select not grayed out.
