System Requirements
digger931
I would like to know if my laptop will run RealFlight Basic.
Here are the specs:
Intel Core 2 Duo T5800 2 GHz
4 GB RAM
Display adapter type Mobile Intel(R) 965 Express Chipset Family
Total available graphics memory 358 MB
Dedicated graphics memory 0 MB
Dedicated system memory 128 MB
Shared system memory 230 MB
Display adapter driver version 7.14.10.1437
Primary monitor resolution 1280x720
DirectX version DirectX 9.0 or better
Thanks for any help.
The photofields will run somewhat okay. The 3D fields won't run well at all on your machine. It's probably just below marginal. It'll do in a pinch, but eventually, you will become dissatisfied with it. That machine is just not designed to run 3D apps.
Well, you guys were dead on. Trying the Demo, though a simple solution, was brilliant. It worked just as stated, the Sod grass field did pretty well while the Boneyard did not.
Should I expect the Basic version to perform in the same way?
If so I may go ahead and get it. As Jeff said it will do in a pinch and I have no other option right now.
I'm impressed with this forum. Quick, accurate info.
Thanks for the help!
RF Basic will perform similarly. You will probably need to tweak some graphics settings though.
