Partially. I also added a bit of shading to define the areas, so even with normal maps turn off you should still see the indentations.opjose said:I assume that you did the details on the flaps, etc. with bump maps, right?
Yes, the model is overpowered (as many RC planes are). This model is based on an existing RC aircraft (see the first post) and scale performance based on a full scale aircraft was not a requirement.Heeleycopter said:I was able to hit the throttle pull back sharply and go into a hover, was this intended.
