twoeleven said:pplace,
Here's a quick resto of the Lion Toon on the fuse. I didn't look for one on the net, just whipped out what i think it might have looked like in PS.
You could change the colors if they aren't right. If you like it, I will send you the PS file if you PM me your email. Sized that small, it will probably look the part?
Plane looks great, can't wait to see the final.
Griff
twoeleven
twoeleven said:No problem, happy to help out...
With the remaining polys you could model the switch under the wing, just a thought...
Looks great, the lion seems happy there.
Griff
twoeleven
dhk79 said:Make sure you don't model the thrust vectors.
Correct. Just make sure that they are named correctly (~CS_SPINNER#) and in the physics editor, under the engine settings, put in the values for the right & down thrust. RF will then adjust the 3D image's offsets for you.pplace said:Take the spinner and reset the visual model in 3ds back to 0 degree from the side and 0 degree from the top (right now it's 5 down and 2 right) also reset the pivot in 3ds to 0,0.
