bob_nj said:
my sim is down now
because of an upgrade attempt.
I Tried to go from 3.5 to 4.5
3.5 ran fine, but I'm now getting the error;
Cannot find import; DLL may be missing, corrupt, or wrong version.
File fmod.dll error 126
This is the error when I try to run from the application file.
When I use the launcher, I get a similar message with this file listed;
NLVSCAN2.dll error 126
Any ideas?
Thanks
Bob
YES I have an Idea...... the key word(s) in the first error are WRONG VERSION
It sounds like you tried to install the free upgrade MENT for 4.0 to upgrade to 4.5 ....INTO 3.5
.....NOT GONNA HAPPEN !!!
They are 2 completely different versions.
If you want 4.5
you MUST buy 4.0(if you can still find it) and upgrade to 4.5 OR buy 4.5
At this point you should try these three options:
1) using the "Restore Defaults" button on the 3.5 launcher under "Additional Options" this MAY set things strait.
2)If That does not work try "reg.\updates" button on the launcher select "Update to Specific Version" and select the current version that you were using before you tried to do the(4.5) "update" but make sure you HAVE a check mark in the "Completely Refresh" box.
3)IF that does not work...you will have to completely Un-install\ Re-install 3.5
to do this WITHOUT LOSING any custom content follow these instructions:
Open the 3.5 launcher under "Additional Options" use the "Uninstall RealFlight" Button
and DO NOT check any boxes except the One that is already checked .
Have your 3.0 disc.s handy for the re-install then upgrade to 3.5 same way you did the first time you did so
hope this helps
