tridge
I'm having trouble getting the yaw torque right for a large dual motor vectored tailsitter.
On a smaller vectored tailsitter we're not having any problems. The two motors are set to opposite directions (one clockwise, one counter-clockwise) and it flies really well.
The larger vectored tailsitter behaves quite differently. The way it flies looks like both motors are turning in the same direction, but they are set to opposite directions and I've confirmed the directions by starting the motors in the vehicle editor and seeing which way they spin.
You can see the problem in this video:
https://www.youtube.com/watch?v=HO4XeMSih1A
starting at around 1:50. The model is hovering in no wind, and should have a small total yaw torque, with the motors pointing straight up. Instead the motors are at a large angle in order to hold the yaw.
For comparison, here is our smaller aircraft with the same setup:
https://www.youtube.com/watch?v=W2OIl7i3EaI
that one behaves as expected, with the motors only needing to tilt when you command some yaw rate.
Can anyone suggest why the larger aircraft behaves like this?
All the model files are here:
https://github.com/ArduPilot/SITL_Models/tree/master/RealFlight/Tridge/CUAV_TVBS
