All the control movements are mind blowing., also notice "flight lever" on right side of the model moves some more and now Chitty is in VTOL/Heli mode.
Inverted flight works good in airplane mode but not in heli mode.i just flew it. I was making sounds of GLEE the whole time. Its flight characteristics are so natural, even in helicopter mode.
Flying upside down is SURREAL!
I bet Caractacus Potts didn't know it could do that!
Chitty is MAGIC!
Yeah but Chitty would use its MAGIC to keep them from falling out.but would not have enough poly's remaining to make the seat belts.
Knifeedge works best if you pulse the rudder.I just flew it also!! It blew my mind. I tried to fly knife edge with it and it's not half bad!!! This thing is crazy. I love it!!!
Are you saying that the sound profile was already in RealFlight?Hey ASJ I see you're using the Wolseley Viper sound profile but with high rpm values for the sound file names. You might consider renaming the sound profile because if anyone tries to use it with a normal engine the sound will be way off from the high rpm numbers in the sound filenames (at least I think that's right correct me if I'm wrong).
Well, I looked at the Radio tab in the Aircraft Editor and can see that the value goes smoothly from -100% to 100%. Hmmmm. Is that the right place to check whether it's my controller's fault?I'm checking whether that's my controller's fault...
Well, I think I saw it happening in your latest video at about the 1 minute mark:Well, I looked at the Radio tab in the Aircraft Editor and can see that the value goes smoothly from -100% to 100%. Hmmmm. Is that the right place to check whether it's my controller's fault?
I created a Wolseley Viper sound profile for my RAF SE5a in 2019 but I'm not sure that's the one ASJ used to create his Chitty Chitty sound profile from. But if he did that's fine with me because it sounds perfect for his Chitty Chitty. He would have needed to change the name of the sound files to match the rpm range of the engine in his Chitty Chitty. In RealFlight the name of each sound file is set to the rpm it matches.Are you saying that the sound profile was already in RealFlight?
The same thing happens with me, in regards to the elev., so I would say that it`s not your TX`s fault.....And Asj, this thing is FANTASTIC...!!!!Here are a couple of things that you probably already know about:
- The rear elevator visual frame pops back to neutral at extreme up and extreme down. I'm checking whether that's my controller's fault...
- Chitty flies (in both modes) whether its wings are extended or not! SEE! IT IS MAGIC! Perhaps this isn't a bug. IT'S A FEATURE!
oh yes. it's easily one of the funnest to fly, best looking, and most unique airplanes ever made for RealFlight.And Asj, this thing is FANTASTIC...!!!!
The elevator jumping back to neutral position is caused by the Linear Actuator I have assigned to it to move and hide the elevator when the wings retract.Here are a couple of things that you probably already know about:
- The rear elevator visual frame pops back to neutral at extreme up and extreme down controller input. I'm checking whether that's my controller's fault...
- Chitty flies (in both modes) whether its wings are extended or not! SEE! IT IS MAGIC! Perhaps this is NOT a bug. IT'S A FEATURE!
Yes it is the Wolseley Viper sound file I am using, I did not realize it was your file Technoid, in the editor it gives no indication of who the author is, (they should give credit where credit is due).I created a Wolseley Viper sound profile for my RAF SE5a in 2019 but I'm not sure that's the one ASJ used to create his Chitty Chitty sound profile from. But if he did that's fine with me because it sounds perfect for his Chitty Chitty. He would have needed to change the name of the sound files to match the rpm range of the engine in his Chitty Chitty. In RealFlight the name of each sound file is set to the rpm it matches.
Good to hear you like the Chitty model. Thanks UT.The same thing happens with me, in regards to the elev., so I would say that it`s not your TX`s fault.....And Asj, this thing is FANTASTIC...!!!!
Nothing wrong with being happyBack to the elevator wag, I see it as Chitty just being happy and wagging it's tail.
