I
01 F-117 Nighthawk 4010 FB V5_AV
F-117A Nighthawk Stealth Fighter.
Very nicely flying and full control for flying fun. Very fast or gliding experience enjoyable.
Wing Span 4880mm
Weight 24Kg
Top Speed 335PH (After Burner ON)
Cruising Speed 335 KPH
Landing Speed 45KPH (Flap mode)
Fuselage is built completely for accurate flight characteristics instead using Root Frame.
Flaps and Elevron are correctly interoperable for easy landing with Gear down.
Flaperon and Elevron with Flaps movement applied. V-tail mix applied correctly.
Camera view angle can be controlled with ch6 knob.
Control Sticks
ch1 : aileron (Flaperon mix and Elevron mix)
ch2 : elevator (Elevron mix) Wheel Break on (stick down)
ch3 : throlle for turbine and After Burner (80% and up) with only Gear up mode
ch4 : rudder
ch6 : camera view angle control
ch7 : Landing gear retract and Flaps control
Camera
F4 ~ F8
F117 is hard to control flight characteristics because of stealth enabled aerodynamics. Intake to Exhaust airflow is carefully built. Feel the flight characteristics you will enjoy.
Have a fun !!
F-117 Nighthawk_EA
