M
Avistar Elite 200 Inch Wingspan Mike's Setup_AV
A huge trainer. Done right with all the goodies.
I've successfully scaled this aircraft up to a 200 inch wingspan.
Of course it's big and beautiful, and you'll be thrilled with how well she flies. Just cruise around, just above half throttle in safe mode, and you've got a great airplane to learn on; But turn off safe mode, go full throttle, and you've got a fun sport plane. Great knife edges, and she hovers. Turn on the smoke and have a blast.
For takeoffs or landings, all you need is 50% flaps, (Should you choose to use flaps.) but she does just as well without them.
This aircraft has been balanced and tuned to fly exceptionally well with no trim, by adjusting the physics, the CG, tuning the incidences of the flying surfaces and motor, adding mixes and applying AS3X flight stabilization.
Brakes: Down Elevator
Dual Rates: Channel 5 (Standard)
Flaps: Channel 6
Smoke: Channel 7
AS3X Mode Control: Channel 8 Three Position Switch (Gyro Off - Safe Intermediate - AS3X Rate Mode)
Eight Camera Views: Keyboard F1 Through F8
Enjoy.
Please rate and comment so that I'll know if I'm on the right track with my setups. If I am, I'll keep doing it. If I'm not, I'll take your suggestions to make things better.
Avistar Elite from RealFlight 8
