20% C-130 Hercules "Fat Albert Airlines" COMPLETE PHYSICS REBUILD.
See it fly here:
***START WITH DUAL RATES OFF*** Reverse prop pitch is active with Ch. 5 dual rates "on" or up.
This 1/5th scale high performance C-130 AV incorporates variable pitch propeller blades that are tuned to increase pitch with increased throttle. After landing, during roll-out, the pitch can be reversed by activating the CH. 5 Dual Rates switch (up position). Reverse thrust (throttle up) working together with full brakes (down elevator) will produce scale short-field stops like the real-world C-130.
To compensate for no dual-rate control surfaces, larger throws with more EXPO are used. The result is an airframe that can be flown well-within a scale envelope, including scale top speed. At full throttle and full control deflection, however, this large and powerful airframe shows a bit of muscle.
Flaps are functional on the Ch. 6 knob
Cargo doors are closed with 3-position switch up, middle position lowers the cargo ramp portion partially. Away or down position will fully open the ramp and open the overhead cargo door.
2010 "Fat Albert Airlines" Livery here: https://forums.realflight.com/index.php?resources/13558
1972 "Fat Albert Airlines" Livery here: https://forums.realflight.com/index.php?resources/13557
Original 3D model by minou
Complete physics rebuild by twoeleven
Enjoy!
Griff
twoeleven
See it fly here:
Enjoy!
Griff
twoeleven
