NEW FLIGHT PHYSICS - This AV is modeled after Danny Lanz's real world 22% Scale Hawker Sea Fury FB11 built from Jerry Bates plans. The flight physics have been completely reworked to simulate the RWM's flight envelope.
Custom matching CS is here: https://forums.realflight.com/index.php?resources/10588
See the RWM fly here:
Aircraft Details:
Wingspan 101"
Weight 47 lbs.
Construction from built up and glassed balsa and ply
Powered by a 3W 157 with 18hp
Custom semi-scale exhaust
30 X 14 two-blade wood prop
Scale articulating retracts
500 hours build time
RealFlight Aircraft Specifications:
Six Channels
-Throttle
-Ailerons
-Elevator
-Rudder
-Retracts- Controlled by the 2-position switch on the top right of the InterLink Plus controller.
-Flaps- Controlled by the 3-position switch on the top left of the InterLink Plus controller.
Dual Rates- Controlled by the 2-position switch located on the front left of the InterLink Plus controller. Scale flight is best without Dual Rates.
AV and CS by twoeleven.
Enjoy!
Aircraft Details:
Wingspan 101"
Weight 47 lbs.
Six Channels
-Throttle
-Ailerons
-Elevator
-Rudder
Enjoy!
