rcdoski
F8F-2 Bearcat UNLIMITED- Ultra Reno Racer-2_AV
This AV was designed to be used at my Ultimate tubes and maze ultra-airport for pilot spawn 6. Which is the start of the air race course around the desert. This AV is very fast and has a long flight time at full throttle. It flies very smooth and is easy to land. I recommend most of your flying in low rate. Turns at high speeds will create wingtip vortexes.
Smoke and canopy on channel 8. Canopy open / canopy closed / smoke on -switch away from you.
Channel 7 retracts.
Channel 6 flaps.
Channel 5 High/Low rate.
Brakes on up elevator.
Make sure you check out all the camera angles.
I have to thank Technoid for creating the original EA F8F Bearcat and also DDawg for the color scheme.
I hope you have fun with it.
Enjoy. https://forums.realflight.com/index.php?resources/binturong-brutus-f8f-2-bearcat_cs.24137/
F8F-2 Bearcat_EA
