Electric powered variant of the TF Beech Staggerwing. Utilizing the original TF model, I used the Rim Fire 63-20-250 Outrunner motor powered by an 8000 mAh LiPo battery, turning an APC 16X12 prop.
Flight speed is approximately 68-70 mph at 3/4 throttle. CG is located at approximately the specified located required by TF in their kit instructions (5 1/2" aft of lower wing LE).
If this works for you...enjoy! If not, there are other electric variants out there.
