dhk79
Two Cow Cove - Small Scale_AP
Two Cow Cove at Lake Pleasant is a perfect location to fly your amphibious aircraft. A wide open, unobstructed expanse of water sits under a cloudless Arizona sky. There's not a boat in sight as you taxi out to take off.
There are three variants to this field; listed as Small, Medium, and Large Scale. This refers to the scale of the planes to be flown on the field (the only difference is how deep the plane sits in the water). The default field is the medium scale, which includes the panoramic scene. This is field suitable for most aircraft (say .40 to .90 sized). The other two are adjusted accordingly.
This file has been updated to remove the area behind the pilot, where the plane could go under ground (but you can still smash into my car).
Objects on this field are not compatible with G4, but a comparable field was re-released for G4.
DHK
