K
Typhoon Heavy_EA
Typhoon 2M composite glider from RCRCM. This model is based on a single carbon version. This version has added 1000 grams of ballast in the tube.
The model has a good roll rate, have not flown the real one yet, but hope for feedbacks for those actually flown
it, if it's really differ in behaviour, the goal was to have it as near as possible in behaviour as the real one.
This is a full house glider, with aileron and flaps and crow brake on the slider/throttle stick.
Channel 8 three way switch is assigned to (speed=down/ neutral=middle / thermal-launch=up) camber setting of aerofoil.
Channel 7 to way switch is assigned to activate the (on=foreward) flaperon mix.
You may want to turn this off while DS'ing it on a DS hill. Actually, if DS'ing this model, which it does good, also
put on low rates=backwards, channel 5 two way switch to obatain better control in DS rounds / ellipses.
Hope you like the model, and are happy to receive any inputs to make this model more optimal.
