technoid
SO.. You buy 1,800 dollars worth of computer parts, shock gasp, what! Then you backup everything on a perfectly working 3TB hard drive and proceed to tear your computer down except the case and power supply and blow it out really good and set everything on the table to start installing your new parts. BUT you think gosh I'm going to take that 3TB drive in the bedroom where the file server is and put it in my USB 3.0 docking station and make sure everything is ready to copy back to the new system when it's done. You turn the docking station on, the hard drive spins up and makes a very strong seeking noise like going from the beginning to the end of the surface trying to find something and then stops. Then after about 15 seconds it does that again, and again, and again. So feeling kind of empty you turn the docking station off and try another 3TB drive, identical drive mind you, and it works perfectly. So you go, ha must have been a fluke so you put the drive that everything is backed up on back in the docking station and turn it on and the drive spins up and makes the odd seeking sound every 15 seconds again. So now you're in a panic because you have everything on that drive, EVERYTHING! So out of desperation you go to Best Buy, the only place in this town to buy anything and a small one at that and get the only one they have a Thermaltake Duet USB 3.0 docking station which has two hard drive slots. After you get home you say a prayer and turn it on with the good drive and it works, so you turn it off and add the backup drive in the second slot and turn it on and it spins up and works okay too. Your heart is much better now and you make sure all the data is there and it is, so now life is good again. But let me tell you that's a sinking feeling because I had everything backed up on that drive. And why oh why did two identical drives not work in the Old Thermaltake single dock station but work in the new Dual Dock station? But it does, so I took some time and backed up all the important stuff on the second 3TB hard drive just in-case. So that was my scare that took me some time to get through and slowed me down on my upgrade. So I started back on it today but didn't get all the hardware finished so I'll finish it up tomorrow and start installing everything again. Now that was not fun!
