Extreme Flight Slick 580 85
I improved a few things in the blue cs when I created it so I needed to go back to the red cs and update it for the changes I made in the blue cs. Things like the color of the pilot body and the spec map value for how glossy the pilot is. So I did all the fix ups in the red cs so both the red and blue color schemes use the same values. So right now I think the plane is ready to go. The plane will be released in RF 9.5 since EVO now uses their new material system which isn't backwards compatible to the older RF versions. But the new EVO will import and use swap page planes built for older versions of RF. The short of it is, if I release a plane built in EVO with the new materials system it will "not" be compatible with older versions of RF. So the easy thing to do is release a RF 9.5 version and that will work in the new version of EVO with the new materials system and also work for the older versions of RF. It's a shame I can't release it in EVO but this is a decent workaround for the new EVO materials problem.
I just went back and deleted the Slick 580 from RF 8, RF 9.5, and RF EVO and then shut them down and deleted all the left-over files. I plan to do a fresh build tomorrow and install it in all three versions to make sure everything is okay. Then I can think about when to release it after I test them a little to make sure everything is working okay. So, it's getting there. And this test will be the first time I've seen @rcdoski physics. But with a broken shoulder I don't think I'll really fly much. I'll also do a fresh build of the blue color scheme and send both the fresh EA and CS to rcdoski to test too.
I just finished doing a fresh build of the EA and CS and sent them to @rcdoski to test. If there's nothing wrong this will be the release version. I've only tested it in RF 9.5 so far but I'll install the new build in RF 8 and RF EVO too. My shoulder is bothering me today, so I'm take it easy.
I just finished installing the fresh build in RF 8 and RF EVO and everything seems to be okay. I'm depending on @rcdoski for checking the flight physics because with my broken shoulder I can't really fly it.
I just got done flying it and it is nice. Just needed to make some strength adjustments so it doesn't break in aggressive menuvers. Other than that I think it's good to go. Flying it at a 3D field from all the different camera angles is fun also.
Okay, cool. I'm looking forward to flying it once I get better. But the little bit I tried to fly it was great. Thanks for some super performing 3D XA physics.
@rcdoski had a few values he wanted me to change in his physics so I made the changes this morning and sent him a new EA and CS to test. It looks like this is the last change so the plane should be ready to release after he verifies I made the changes correctly.
Everything looks good. You have created a beautiful model Technoid. Whenever you are ready to release go for it.
Okay, thanks. I'm glad everything is working well. I'm not sure when I'll release it, but soon. It revolves around how my shoulder is doing.
