MS Win7, RF G5 installation failure issues
Dear RealFlight support person,
I have tried several times to install RF G5 on the newly installed 64bit Windows 7 OS on my laptop.
It had previously installed fine under 64bit Vista, but now after installing Windows 7, it will not install.
I have corrected some driver issues, and uninstalled some software, some said may have created a problem, such as ITunes, and others, then I removed upper and lower buffers related to the DVD player in the registry, but RealFlight G5 still will not install.
I copied the DVD to a USB hard drive and tried installing from there but it gives a message about a previous installation failure and prompts to pull data fromt he DVD which it cannot access.
Every time I put in the RealFlight G5 DVD it spins up and keeps spinning at an inaccessable rate.
Most other CD's and DVD's are working fine, most do not speed up and maintain said speed like the RealFlight DVD does.
Albeit I had a problem installing MS Office, which I resolved by coping to the USB hard drive and successfully installing from there.
Also, RealFlight G5 will not install onto my AMD based Desktop system.
So now I cannot use it at all.
I hope corrections to be made on a DVD that can be used directly or by copying to a hard drive and then installing from that location without the need to access the DVD.
It would help if RealFlight was designed so that it could be copied to a hard drive and then installed from there when such instances of seeming incompatibility occur.
The current DVD always locks up windows explorer, "My Computer."
So I am stuck and RealFlight G5 is not working.
