The first is what I call a ghost around the airports, which is square in area over the airport, transparent, and slowly disappears as an aircraft approaches the airport. It is annoying. I can't seem to get rid of it.
The second problem is that if I put an airport a great distance from the first airport and try to fly to the other airport, I get excessive cabin flutter/shack as I get further away from the airport I took off from. Is there any easy way to fix this other then putting multiple airports close together?
Here's what Ryan Douglas had to say about that in this thread.The second problem is that if I put an airport a great distance from the first airport and try to fly to the other airport, I get excessive cabin flutter/shack as I get further away from the airport I took off from. Is there any easy way to fix this other then putting multiple airports close together?
I have an airport question, is it possible to lower the clouds?
The square or rectangular ghost you describe is probably because your using a "concrete" runway. This has been in RF for years and years. I have had all the RF programs, from Deluxe to RF-X and still have 6 thru 9.5 on my comp. I quit using Concrete Runways and the ghost went away.Thank you for the reply. I am on my fifth airport now. I have used trial and error (much error) to get them to work. I have two main problems that remain.
Sorry for the questions, but I have exhausted my ideas on fixing these.
Anyone can put together an airport with all of the available objects, but there would be a heck of a strain on the machine trying to render them all. Even top end gaming machines have their limits, and that's before you consider the timely reminder that @technoid posted about the problem with floating point math.Can someone put together an airport with all the custom scenery?
