My experience utilizing the IGPU Intel UHD 770 graphics (CPU onboard GPU) with RF9.5s.
How to enable RF9.5s when using the Interlink DX controller.
Start Realflight 9.5s, the plane will appear on the runway, it will not move, and the menu bar will be greyed out, click the Esc. key or press the interlink reset button, the menu bar should now be enabled, and you can control and fly the model.
How to enable RF9.5s when using the Interlink Elite or X controllers.
Start Realflight 9.5s, the plane will appear on the runway unresponsive, also the menu bar will be greyed out.
Disconnect the interlink controller USB plug for about 3 seconds, then plug the controller back in again, double click the "Esc" key or press the reset button on the controller, the menu bar should now be enabled, but the plane will still not move, or control surfaces respond to stick inputs from the interlink, click on "Simulation" tab (top left screen) click on "Select Controller" and wait for about five to ten seconds, the plane should now respond to controller inputs and you can enjoy flying in the simulator.
Yes, you will have to complete either of these methods every time you start RF9.5s
The good news is planes and Drones load and fly good, the bad news is selecting any helicopter will crash the system and RF9.5s will need to be restarted,
Helicopters generate an error code: D3DERR_INVALIDCALL, DXDevice.cpp, line 118. (clicking "Okay" does nothing, click "Cancel" restarts RF9.5s).
The above methods will get RF9.5s working but it has limited functions, such as, not all the Simulation menu options are available,
If you click on "Select Scenarios", "Manage Scenarios", or Physics tabs nothing appears to happen, if you click on "Graphics" tab the menu bar gets greyed out again, the system becomes frozen and RF9.5s will need to be restarted.
Usually when you click on the "Select Controller" tab you get a popup screen that allows you to select the controller or calibrate it, that screen does not appear, so you have no way of calibrating within RF9.5s. (use joy.cpl in Windows to calibrate).
When the mouse curser is moved over the left side of the main window screen, the graphical icons for Select Scenario, Select Aircraft, Select Airport, NavGuides, Radio, Binoculars, and Viewport do not appear.
These are the only ways I have found to run 9.5s when using the Intel 12th or 13th gen CPU with the integrated IGPU. (UHD Graphics 770).
