Sky Fly Max
mark-b
Does anybody have, or can create a Sky Fly Max ea file? It's a way different plane than the Sky Fly 1 and 2, in that it has ailerons and a 48" span.
Thanks;
Mark :)
By pics, he means straight on shots from the side, front, and top. Snapshots from your family vacation with your model really won't do.
I was going to get the Rookie posted before I started anything new, but I don't what to do about the mapping on the Brison engine. I am trying to get a new F22 ready to fly at the electrict fun fly at Thunderbirds field this Sat, so I will work on this when I am resting.
Your SkyFly Max comes complete with:
• Durable Aerocell™ foam airframe
• Powerful brushless motor
• State-of-the-art Tactic™ 2.4GHz radio system
• LiPo battery and charger
• Four “AA” transmitter batteries
Specifications:
HCAA2511
Wingspan: 47 in (1195 mm)
Wing area: 390 in² (25.2 dm²)
Weight: 27 oz (770 g)
Wing loading: 10 oz/ft² (31 g/dm²)
Length: 39 in (990 mm)
I started with a cube, 47"x 7" x 1.3
Made the main gear and wheels.
Specifications:
HCAA2511
That is amazing. Just from small captures, you got the basic shape down, and of course, the specs from any online hobby shop. It would take me a while to figure out how to do that. Thank you for getting that far into it.
It will help, if you can get me some stright on front, side, top and bottom picks. It will be more corect that way. Other wise it will be stand off, look good fram a destance.
got all I need
I found some more picks, these are all I need. Unless you could get me one looking down on the motor so I can see how it mounts.
motor from above
Here's 2 shots; one with wing on.
The pick still does not show how it is mounted. Does the motor slide on to a square piece of spruce?
yes, a wood block inside styrofoam fuselage
yes, a wooden block in foam fuselage. just curious, but how does it influence the physics part of it?
