Dr.Moo!
E-Flite Blade mSR (More Realistic)_AV
--Original Description--
Weighing in at under one ounce, the nimble Blade® mSR RTF takes ultra micro helicopter performance to the next level. It comes from the factory completely assembled and flight tested with everything you need to get flying. At the heart of the Blade mSR’s design is a Bell-Hiller rotor head that provides the kind of speed and agility you would expect of a single-rotor heli but maintains a measure of positive stability similar to a coaxial heli. This blend of agility and stability makes it the ideal “next step” for someone moving up from a coaxial heli, such as the Blade CX3 or Blade mCX.
For single-rotor ultra micro heli excitement you can fly almost anywhere, the Blade mSR simply can’t be beat.
--Aircraft Description--
This is a E-Flite Blade mSR originally modeled by "oneeyejack" for RealFlight G5. The Physics edit was done by "Dr.Moo!" along with the Cameras. Visit http://drmoo.jimdo.com/ for more edits by "Dr.Moo!"
-- Controls--
Channel 1 Aileron
Channel 2 Elevator
Channel 3 Throttle
Channel 4 Rudder
Channel 5 Dual Rates
Channel 6 -- N/A --
Channel 7 -- N/A --
Channel 8 -- N/A --
--Cameras--
F1 Fixed View.
F2 Nose Camera.
F3 Chase View.
F4 On-board "Boom" View.
F5 On-board "Cockpit" View.
F6 On-board "Forward Facing" View.
F7 On-board "Gear" View.
F8 On-board "Rear Facing" View.
F9 On-board "Skid" View.
F10 On-board "Swash" View.
If you get an error saying "Unable to find <<insert battery, motor, blades here>> Restart RealFlight and it will have all the correct items. Also, this edit is fudged a little since the Flybar on the mSR over compensates for the little heli, So I used AFS Gyros and Expo to get the same effect.
Please Rate and comment.
Blade mSR_EA
Latest updates
  1. Images
    Images
