This is a 350 kph+, 1m wing span, 4kg, 30N gas turbine powered, hand-launched (!) variant of Nizz's fun, but very smart, J10Mini_EA.
(It would be good if a retactable gear set could be added by someone. A hand-launched gas turbine powered model is stretching things rather!)
Although she is good for over 350 kph flat-out (with just 30N of jet thrust!), she is rather more managable when the throttle is pulled back a bit!
Again the model is provided with flaps but, as per Nizz's original design, these are operated by the elevator servo system.
On Nizz's J10Mini_EA page on the swaps he noted: ON CH7 Aileron / Elevator Mix - I'm not quite sure what he was getting at, but I reproduce it here in case it helps anyone.
Thanks again Nizz. I just love your work! Keep it up - we all appreciate it.
Nigel_B
Nigel_B
