Doug, I can knock the block over when I back into the ring with the hook, and I can knock it over with a ski. But, when either the tip of the ski, or the hook itself enters the ring, it appears to cut through it and the weight rocks and then stays put. I have tried enough times that I am convinced I can get inside the ring, but it cuts through before it lifts.
That being said, very cool. For the purpose of the test, a slightly longer hook, and a slightly larger ring might make the trials go quicker?
I think you are close to a game within a game, if the interface will work, I am imagining different weights with different sized rings...VERY challenging, especially with the smoke, I turned the exhaust way down for better visability.
Anyone lift it?
Griff
twoeleven
