Boof69
I did get the email but seeing the pics the solution should be to connect the top and bottom verts. Select all of the edges from root to tip and follow the tut I made for sealed hinges. The new edges added should follow the contours as expected. I will check this in the morning but if the verts line up over each other I'm sure it will work.
