i wouldn't worry about that technoid , if you did that with the real RC model it would likely leave the wing behindThis morning I chamfered the servo wiring to make it look a little better. I also tweaked the cinema cam a little. I can break the wing off just doing hard aerobatics like I would normally fly down low. Of course this is a fairly lazy flying plane so they're not crisp, but the point is I can still break the wing off doing them down low. In fact that's how I found out the wing would break off. And to get it to stop I have to add a lot to the wing strength setting. I went up to 160 from 120 and I could still do it. So I'm not sure what to do with it.
It was a bit different than that, but overall that was right. What I did was "cut" each wing in the center to create the saddle for that side. Then I exported those two pieces to a different file so I could import them and have the normal wings and the saddle. Then I expanded the center piece to create a saddle that was a little larger than the wing. BUT. Later I attached each saddle to it's wing and then welded all the verts so the wing was one piece again, but with a center section that was a little larger than the rest of the wing. So after that there was just the left and right wings like normal.Tech. If I recall, (correct me if I`m wrong) you modeled the wing in 3 pcs. a lft/rt side/and a middle section, can you join them all together so that the wing is in essence one piece. ???
I'm still using the older version I've used for years. So is that supposed to be okay? I guess the thing to do is use the "kex" file generated by the RF 9.5 DVD import process and release it that way? Which is what I've been doing and I guess why I've never noticed this problem until now.I have noticed the same issues with Max 2023, waiting for the fix as Ryan said they are working on, Max has dropped support for Scanline.
Caution 3ds Max users
In versions of Max after 2020, Autodesk removed support for the scanline material type which RealFlight requires. Given 1) the release of Max 2024, and 2) Autodesk's policy of only providing access to the three most recent versions, it is no longer possible to obtain and install Max 2020. The...forums.realflight.com
I went back this morning and rounded the back of the wingtips to get rid of the shading and it looks okay now. BUT I found another problem that hopefully @legoman can shed some light on. Here's two pictures of the same build "but" how it was imported into RF EVO.
For the first picture I exported the max file to an fbx file and then imported that fbx file into RF EVO to create the kex file. But for the second picture I exported the max file to an fbx file and then imported the fbx file into RF 9.5 DVD to create the "kex" file and then imported the "kex" file created by the RF 9.5 DVD import process into RF EVO. The import process allows you to import a "fbx" file or a "kex" file. SO the kex file generated by the RF EVO import process causes the black areas on the plane but the "kex" file generated by RF 9.5 DVD import process looks just fine. And the really bad black areas are on the right side of the plane.
View attachment 137468View attachment 137469
Yes the Left picture is EVO and the Right picture is RF 9.5 DVD. So your MIG looks the same to me in EVO and 9.5, is that what you were showing me. Like I mentioned I normally build the fbx and import it in RF 9.5 DVD and then use that kex file when I import the plane in EVO to release it.is EVO on the left and 9.5 on the right in your images? What versions where the images taken in?
here is what the mig-21.KEX looked like from evo (L) and 9.5s (R) (both pictures were taken in evolution)
View attachment 137471View attachment 137470
if you are releasing the plane in EVO just transfer the 9.5 plane over to evo.
also my take on the plane breaking too easily concern. if the only way you can break the plane reliably besides unplanned one point landings, is an inverted snap roll. It is just fine and likely a bit too durable.
Thanks.. For some reason I thought they were open and I couldn't see the doors (smaller picture and bad eyes).Look at the nose gear doors, Evo gives the impression they are concaved.
