Sky Fly Max
Well, that's strange. I'm using the EA that you attached earlier and it definitely doesn't show up there.
I'm going to export it into G5.5 and see what happens there.
flexible said:
I see, all you did was import the Kex, you did not make the wire frame. Open the G3.5 version in G5
It works fine that way too.
I converted your Max file to 3ds and ran it through the 3ds2kex converter and then imported to G3.5 and loads fine that way too.
I'm stumped as to what's causing it.
One thing that just cough my eye is, what type of component you added to the wire frame. Did you add a single wings and rotate it down?? RF might be detection a wing crash causing your problem. You can try adding a single fuselage component to the ~CS_tailskid
Changed the componant to a fuse, but made no defferance.
