I agree on the assessment of the Windows USB Joystick interface. The first 8 channels are proportional, and then there are a whole pile of buttons, which we would normally assign to 2-pos switches. You can assign the sticks, sliders, pots, or >2 position switches to the proportional channels. You could also assign a 2-pos switch to a proportional channel, but you won't make any friends doing that. And you may have a calibration problem.
I've assigned the 6-pos switch to a proportional channel. Even though it's impossible to set it to 50%, after a couple of presses of most of the buttons (1 and 6 alone would probably suffice) all of the buttons generate the correct values.
The Interlink controller has the nice feature that you can hold the momentary contact up/down button to scroll up and down through the list of models or airfields. I believe the controller reads the state of the switch, and then generates a bunch of up or down presses to send out the USB port. There's isn't an input device on the TX16s that can do that. (Light bulb turns on!) Can a LUA script or special function do that for a 3-pos switch? I'm fairly new to OpenTx, but it seems like it should be possible.
So far, it seems we've established that more than one of us has seen the 64% trim problem after calibration in RF8. And we've also seen examples of not having the problem in RF8. But we don't know what causes the issue, or more importantly, how we should set up the radio to avoid it.
And so far, it hasn't been observed in RF9. But that doesn't mean it won't happen.
