ok i miss under stood what CS was requested and this is the one he wanted
https://forums.realflight.com/downloads.php?do=file&id=24419
Well oranges are good for you.. high in vitamin C
I just grabbed it.
I don`t think that`s eggxactly what he wanted to hear BD....Orange you gonna make another .. sorry .. couldn't resist
Here we go
I thought I'd go back and see what I could do with an EP version of the Monster Stick so here's a beta. Please let me know if you find a problem.
Here's the parts I used and their cost.
HACKER Q100-5L - $1,099.00 EUR
TURNIGY 5000mAh 6S 40C - 4 Each at $63.92 each ($255.69)
Note: Batteries are connected 2 in series with a parallel pack connected the same way.
Sweet .. You know I've been doing some big electrics also. Seems nitro is now becoming even less popular since fuel prices have more than doubled. Not to mention the restrictions placed on them because of noise even at clubs.
BTW I got an error message about the motor not found and a default would be used. I'll see what I can find in the default ones for now.
- the collision mesh for the fuselage still encompasses where the radial engine was
- I reduced the resitance of the motor in notepad to .0053
- I moved the current limit to 440 amps (2x the recommended esc)
You might consider tapering the front of the fuse.... from the top, bottom and sides,of the fuse, to their respected sides at the front of the block. that`s a pretty BIG block out there..... Just a thought
Either I guess, no matter which of the two options, In the end, the results would still look the same.Do you mean taper the Engine Box or the Fuselage?
legoman. I sent a PM to Jeremy and just got an answer. He said the code didn't clamp the motor resistance value to 0.01 so I could edit the file like you mentioned and set the motor resistance manually to .0053, so that's what I'll do. Thanks again for bringing it up. Oh he mentioned a value lower than 0.01 hasn't been tested but didn't expect any fireworks. All three of the items you mentioned will be fixed before release.
On another note I have Rage ready to release and I guess Stagger is next. I want to clear out my betas before I start on the Super Chipmunk.
