ja esta esse ae.RealFlight64.ini
Boa tardeEm uma nova instalação executada pela primeira vez, o RealFlight tenta determinar o idioma principal definido no Windows. Se for diferente do inglês, o RealFlight tenta carregar traduções para o idioma detectado. Se não existir tal arquivo de tradução para esse idioma, ele exibirá a mensagem de erro que você relatou e deverá mudar para o inglês a partir de então. Você deverá ver essa mensagem apenas uma vez e o software ainda deverá funcionar normalmente depois de clicar em OK.
Consulte este tópico para obter mais informações, incluindo algumas etapas que você pode tentar. Observe que para você, "<Documents>\RealFlight 9" deve ser "<Documents>\RealFlight Evolution" e "RealFlight.ini" deve ser "RealFlight64.ini".
RealFlight64.ini"Have a look in your OneDrive/Documents Folder.
I renamed .bak and .old it still gives the same error.Rename the RealFlight64. ini file, maybe add a .bak or .old suffix, that should force Evolution to write a new .ini file for you. I would do the same to both Document locations (Documents and OneDrive/Documents) Close Steam and RFE, restart and test.
No, because the error is language, I don't think it can be directx11, but I'll test it now.Have you tried installing the DX11 beta?
DirectX is a programming language written by Microsoft and is backwards compatible, meaning DX12 works with DX11, and DX10. So it's okay to run the DX11 Beta on your computer. It "will not" replace your DX12 it's just "written" in DX11 but will work fine with DX12 because DX12 is backwards compatible. It will even work with DX9 which is really old.because I'm already using directx 12
I installed dx11 beta but still the same errorDirectX is a programming language written by Microsoft and is backwards compatible, meaning DX12 works with DX11, and DX10. So it's okay to run the DX11 Beta on your computer. It "will not" replace your DX12 it's just "written" in DX11 but will work fine with DX12 because DX12 is backwards compatible. It will even work with DX9 which is really old.
I haven't followed this much, but it seems you said it's a language error. What language is your windows setup to.I installed dx11 beta but still the same error
I installed dx11 beta but still the same errorHave you tried installing the DX11 beta?
PT-BR PORTUGUESE BRAZILI haven't followed this much, but it seems you said it's a language error. What language is your windows setup to.
Have you tried using the Simulation-Settings-Lauguage to set the language to an installed language. Maybe they don't that language available.I installed dx11 beta but still the same error
