We have just discovered a compatibility issue between G5 and older CPU models. It manifests as a crash in setup.exe (not setup2.exe/Installer2) as soon as the G5 disk is inserted into the drive. Note that it appears similar to the DEP-related issue where Installer2 crashes immediately after inserting the G5 disk, but it is a completely different problem.
We are working on a fix. In the meantime there is no workaround except installing on a different computer.
The following CPUs are affected:
Intel Pentium III or older
AMD Athlon (650 MHz – 1400 MHz)
AMD Athlon XP (1500+ – 3200+)
AMD Duron (600 MHz – 1800 MHz)
AMD Sempron (2000+ – 3300+)
AMD Athlon MP (1000 MHz – 3000+)
AMD Geode NX (667 MHz – 2200 MHz)
