Ive got the other pars going just fine, its just the fuse thats giving me fits. I had to basicly hollow out the entire fuse so I could do the framework and the inside faces that wont be seen is the problem. Im assuming I can just scale those parts down real small and stack them on top of the fuse parts? that way they would be the same color at least.Junkboy999 said:If you have a lot of little stuff that will not be see on the model CS you can map them to a small area of the map , say a corner, and just paint the corner black, If you do not want to paint those area you can just asign them a texture color. Mapping takes a bit to learn. Lot of trial and error. some times just looking at other people mapped CS will give you an ideal of ways to cut and map your project.
That works. And, you know, put a balsa pattern on top.abaser said:Ive got the other pars going just fine, its just the fuse thats giving me fits. I had to basicly hollow out the entire fuse so I could do the framework and the inside faces that wont be seen is the problem. Im assuming I can just scale those parts down real small and stack them on top of the fuse parts? that way they would be the same color at least.
dhk79 said:If you want it, here's a couple of clean balsa images.
Doug
