technoid
Thanks. I hope it works for you okay, let me know. (and any problems you see too)That looks really good. I wish my plane looked that good. I will try it on RF tonight.
Okay great, I'm glad you like it.I just tried it on RF. It is perfect.
Ha Ha, NOW, you`re going to have/want to put some on your plane....I just noticed that the plane has retracts.
Yeah it's a full-service plane.I just noticed that the plane has retracts.
And you should notice the plane flies better with the gear up. The gear up and down affects the CG so I adjusted the CG with the gear up.I just noticed that the plane has retracts.
I've done a few warbirds but mostly I do rc planes. What I like the most is creating my own versions that look like an rc plane or a warbird but with larger wings, stabilizers, and control surfaces so they perform better. I'm one of those guys that like to flip flop the plane around close to me just to have fun with it. I'm not a 3D guy just Fun Fly. Legoman and asj5547 are the scale modelers.You did a great job with the Tiger-120. Maybe next you could make another one of my planes, an A-24 Banshee. It was the Army version of the SBD Dauntless. Then I would have all eight of my RC airplanes available in RF.
Use the ARF CS.....I went back and remapped the inside of the exhaust pipe so I could paint it dark then created a new template for the color scheme. Then I updated the color scheme with the new mapping and also updated the spec map. I also reworked the physics for the 2-stroke so that's done too. The 2-stroke weighs less than the 4-stroke so the wing loading went down so it fly's a bit nicer. I think it's finished but I'll fly it a little more before I release it.
SO.. what color scheme should this plane have? Should I release it with the same Red and White CS that's on the other Tigers I modeled and release the new ARF CS as an Add-On? Or should I use the new ARF CS for the release and have the Red and White CS as an Add-On?
No it will be released on the Swap Pages. But I'll post here that I released it so you'll know.Looks really good. The details with to the name on the prop.
Will you post here when you release it?
