For an initial pick on an airfoil, use the side view and measure cord & thickness of the wing. Divide the two and that will give the thickness % for the wing. Draw A line from the leading edge to the trailing edge, the difference between the area above the line and below the line is the Camber. Now open the spreadsheet of airfoils in RF and with the two numbers you just found, you can find a close match in RF.
