Fly_electric
Great work Donamy!
Thanks. Strengthening the gear definitely makes it turn better. I still prefer the up elevator to stop.
I think this one might be done. Just need to touch up the textures a bit.
After loading or a reset retract the gear and the plane does what's expected. But hit the reset button while the gear is still up and the plane spawns with the nose down (nose gear up) instead of all the gear down.
After loading or a reset the nose gear doesn't turn with the rudder.
With any speed while taxiing the steering affect is very low. The nose gear doesn't turn the way it should.
Plane spawns with the nose gear turned to the right.
A beautiful plane but I've noticed a few things I wanted to share.
the plane uses brakes to steer
I came back to the forum to post after looking at the physics and noticed the nose gear was set to Swivels Freely. I suppose that was mentioned on the Swap Page but the plane doesn't a description and I didn't read the swap page. So does the real plane steer with the brakes?
Yes. The real plane steers with differential braking, and the nose gear is free spinning.
